If your teeth are stained, discolored, worn, chipped, broken, misaligned, misshapen, or have gaps between them, cosmetic dentistry can give you a better smile. This procedure improves the appearance of your smile. Cosmetic dentists work with you to develop a treatment plan. Cosmetic dentistry is the best dental procedure which is used to refer to any dental work that improves the appearance of teeth, gums or bite. It primarily focuses on improvement in dental aesthetics in color, position, shape, size, alignment and overall smile appearance. Cosmetic dentistry offers several procedures that will enhance the appearance of your teeth and your smile.
Services provided by Cosmetic dentistry:
- Teeth whitening are the cosmetic dental process which can be done using powerful products.
- Veneers are a thin layer of ceramic or composite resin tooth-colored material placed over.
- your teeth to improve their shape, size or color.
- Bonding involves using tooth-colored composite resin to improve the shape of your tooth.
- Tooth-colored fillings can improve the shape, size or color of your teeth.
- Bridges involve attaching natural-looking teeth replacements to both sides of a gap in order to close it.
- Crowns, usually made from tooth-colored porcelain, are bonded to your damaged teeth to cover or encircle them.
- Dentures give you a removable plate with one tooth to a full set of artificial teeth.
- Braces involve a system of brackets glued to your teeth and tied together with steel wires and tiny rubber bands to gently move your teeth.
SAI Laser Dental Care is the number one clinic which offers Cosmetic Dentistry and helps the clients to maintain their oral fitness. This clinic is your one stop solution which has gained top position in the field of dentistry and provides the quicker, more effective and in many cases pain free dental procedure to improve the beauty and function of the dental condition. Backed by the years of knowledge and experience this clinic offers sedation and use state-of-the-art lasers for making precise incisions. All the dentists of this clinic are well trained and certified to provide the comprehensive range of cosmetic service and improve your confidence.
