Scaling and polishing are two of the most common dental procedures which is intended for prevention of disease. When scaling is involved to remove the calculus deposits or stains on the teeth polishing is used for the prevention of teeth problems. Although scaling is performed on the teeth, it can also be applied to the roots particularly in cases when periodontal pockets have already formed. This happens when the bacteria have already invaded the gums. Polishing, on the other hand, is the process of smoothing the teeth as scaling can make the teeth feel rough. During this time, the dentist may also provide additional protection to the teeth by applying a small amount of fluoride. These are the best procedure which makes teeth appear whiter, stain-free, and glistening. Scaling and polishing improves dental health and aesthetics of the teeth.
How the procedure works:
Scaling and polishing procedure may begin by applying a local anesthetic to the gums and teeth to minimize discomfort. The dentist then uses a variety of instruments for scaling. The dental hygienist usually begins with an ultrasonic instrument that sends vibrations to the teeth to loosen the more visible and large deposits. The instrument emits cooling mist made of water to wash the debris away. Once the big deposits are removed, the dentist may then shift to scaling process. After scaling is completed, the dentist may then proceed with polishing using a hand piece equipped with a cup filled with soft rubber. The paste, which is usually made of fluoride, is then placed on the rubber cup. The dentist smooths the newly cleaned areas.
Why choose us?
SAI Laser Dental Care is the well known clinic which has gained specialization in Teeth Scaling and Polishing treatment and offers a shining glittering smile to its clients in comprehensive way. Over years of experience this is the best clinic which brings advance infrastructure and state art of equipment to perferm the job in smart way and satisfies the patients with their needs. All the dentists of thus clinic are expert and proficient enough to understand the problem of the clients and provide the best service and help you improve the appearance of your teeth.
